15
This discussion topic has been answered Discussion topic: Sky Sports + Pixelation issues affecting Glass & Stream 20th July 2025
New thread created with title to reflect issue
Confetti Ring
Avatar for GD1
Level 16 icon
This message was authored by: GD1 Answer
Re: Sky Sports + Pixelation issues affecting Glass & Stream 20th July 2025
This has been raised for Sky's attention, however it's likely it will have resolved itself once the support teams are aware.
*****Post marked as answer for visibility only.*****
This message was authored by: pete1986andrew
Sky sports Plus TV channel on sky Glass Gen 2
The sky sports Plus channel is really glitchy. Trying to watch the darts and it's glitching on and off. It's just the problem with that channel. Everything else is working fine
This message was authored by: andrs
Re: Sky sports Plus TV channel on sky Glass Gen 2
Just put on the darts no issues for me
This message was authored by: peter-marlow+1966
I have been watching  the darts all afternoon  and no problems  here
P c marlow
When I find sky they think it was a broadcast issue so they must have fixed it by now cuz it's working perfectly now. Thanks everyone
This message was authored by: Nightrain08
Sky stream on toob 946mb download speed full fibre puck says connection is good
Sky sports + darts coverage is pixelated and stuttering the audio is fine. I have even plugged into the ethernet now.
I can't keep restarting everything the service is aweful.
Re: Sky stream on toob 946mb download speed full fibre puck says connection is good
This message was authored by: KCD123
Sky glass can not watch shy sports + it keeps pixelating and jumping back a second or two.
We are trying to watch the darts on sky sports + but the screens keeps jumping and the pixels are very big on screen. We have re booted the tv and the sky hub, we have also run a test from the app. Can you help
This message was authored by: 82bit
It's been the same on the current evening session. Looked like old analogue Sky for about 10 minutes, completely unwatchable. Main Event seems unaffected, but they cut to it 40 minutes after the start, so you have to endure the embarrassment that is Sky Sports +.
Sky Glass 65” [Gen 2] with Sky Live
Sky Glass 43” [Gen 1] with Sky Live
Sky Stream Puck x4
Sky Sports & Sky Movies + UHD & Dolby Atmos
Sky FTTP
Sky Mobile SIMO x6
This message was authored by: Fergieboy
Try 401 rather than sky sports +
I had same problem tried restarting, plugging in Ethernet cable, switching Wi-Fi off. Nothing worked just glad it's now on sky main event.
That's better cheers. All they it's nowhere near as bright as sky sports + in fact it's quite dull but at least it's streaming ok
Re: Sky glass can not watch shy sports + it keeps pixelating and jumping back a second or two.
Sky sports main event has it on now works way better sky 401 channel
Confetti Ring
Avatar for GD1
Level 16 icon
I watched both the WTA tennis finals today on SkySports+, the last few golf holes of the leaders,, Indycar and Ferrari live and saw no issues.
Darts is something I never watch, but just been to 410 and all is playing out fine.
