3
This discussion topic has been answered Discussion topic: Sky Sport plus on sky glass not working
This message was authored by: Nrlingdale
Nothing happens when I try to access the menu
This message was authored by: lettice Answer
Re: Sky Sport plus on sky glass not working
When you say not working.
Is this when selecting Match choice from one of the Sky  Sports channels using the 🔴🟢🟡🔵 button on your remote?
If nothing happens, do a settings restart of your Sky Glass Tv or Sky Stream puck;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TV or Stream puck will perform a reboot. It will take a few minutes to complete
The Sky Sports + app that sat in the Apps rail has now been removed on Sky Stream/Glass.
The tile that is there now is just a link to live and upcoming sports rails. More on that below.
From the Sky sports channels, selecting the 🔴🟢🟡🔵 button on your remote will now present a sidebar option and provide the extra streams when available, along with match recap and the F1 race control.
As above, the Sky Sports tile in the Apps rail, has changed to just show the live and upcoming Streams, with each Sports or event having its own rail.
You can also use voice saying 'Tennis', 'EFL, 'Rugby' and the like and it will bring up a Live rail to also select the extra streamed matches, when available and view the upcoming matches.
This message was authored by: Skyrugby
Also struggling with this.... nothing happens when pressing the button
This message was authored by: peter-marlow+1966
My sky  sports plus is working, just checked  it on both my 55inch sky glass tvs  and my puck, rugby  league  matches  are on
P c marlow
Answered - Go to Answer
