Discussion topic: Sky Glass issue with TV
Message posted on 17 Mar 2024 10:07 AM
Message posted on 17 Mar 2024 10:16 AM
Re: Sky Glass issue with TV
@markfrank Have you tried connecting to your hub by ethernet cable? What speeds are you getting to the TV itself (open the netflix app and look for the speed test)
What you describe is normally down to poor speeds either with your broadband service or over wifif.
Message posted on 17 Mar 2024 10:42 AM
No Etherley cable. Speed check 29.53mbps
Message posted on 17 Mar 2024 10:52 AM
@markfrank wrote:No Etherley cable. Speed check 29.53mbps
Make sure WiFi is turned off in the network settings. Sky Glass can stupidly turn it back on and prioritise WiFi instead of Ethernet, even when an Ethernet cable is attached.
29.53Mbps is borderline for allowing Glass to function reliably. Any other device using your broadband at the same time will suck up some of that bandwidth and cause issues.
Message posted on 17 Mar 2024 06:13 PM
What's your router sync speed to the internet?
That will be higher than the WiFi connection speed to the Glass TV😉
Message posted on 17 Mar 2024 07:52 PM
Hello, we are currently experiencing exactly the same issues as you are describing below.
Message posted on 17 Mar 2024 07:55 PM
@ehurn22 wrote:Hello, we are currently experiencing exactly the same issues as you are describing below.
So have you tried the suggestions in the previous posts?
Message posted on 18 Mar 2024 06:31 PM
I ran a check on the Mysky app of the tv and broadband and it detected an issue with our broadband. So I followed the info recorded as a fault and it suggested a reset to the router which i followed. So far so good appears to have rectified the issue
Message posted on 18 Mar 2024 08:01 PM
I would suggest you need at least 60mps of broadband, I had that when I first got sky glass tv and had no problems, I am know on full fibre broadband
Message posted on 10 May 2025 02:48 PM
I am my Third Sky Glass TV s problem. In 6 weeks.
my TV is Gen 1 but it seems Sky are still trying to create a permanent fix ..even with Gen 2 TVs.
if s problem is not fixed soon I shall be sending the to back and demanding a full refund
Message posted on 11 May 2025 11:57 AM
@LeanWalrus what problems are you having
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 May 2025 12:35 PM
Sorry my post was meant to say gigafast broadband 900mps full fibre to the property not 60mps, I do apologise for the mistake
Message posted on 11 May 2025 01:14 PM
@LeanWalrus What problem are you having? If it's the one as highlighted in this thread then replacing the TV won't solve it. It's a firmware issue, Sky are investigating and we are awaiting a fix:
