Discussion topic: Sky Glass freezing on Ethernet connection
Message posted on 14 Nov 2025 09:43 PM
Hi, I see this is not a new issue for people but wondering if anyone can help/assist/listen to me vent!
basically we moved from sky q to sky glass in Nov/Dec 23. By February 24 I contacted sky because the tv was freezing. It's not every day and it happens on any channel and app, it's consistent but not predictable. Since then I think I've called about 15 times, I've gone from WiFi connected to Ethernet connected, upgraded routers, changed cables (then gone back to original cable at their request), reset, updated apps, followed every step sky have asked of me.
I'm currently connected via Ethernet cable (WiFi is off), get anything from 640 to 900mpbs through LAN, but consistently showing as 70-90 through Netflix app. My broadband is with cityfibre. I've been told it's a weak WiFi signal (hence connected), it's a latency issue (it's not), that the WiFi is interfering with the Ethernet (their two separate paths so not sure how they get to that) even though we rarely have more than 5 things on the WiFi at the same time (a couple of phones, iPad that sort of thing) and that they can't tell what kind the makeup my router is like because it's not one of theirs! I'm exhausted from trying to get to the bottom of this. I've had callbacks promised that never happened, I've spent hours on the phone now resetting and repeating myself time and time again. It's taken me raising a complaint to get them to even listen.
The latest from them was to reset everything again, turn off all my WiFi connected devices and turn them back on one by one every 12 hours to see where the interference is coming from!
I suppose my question is am I missing something? Is there anything else I should be doing? Or is there anything I should now be requesting or insisting from sky? TIA
Message posted on 15 Nov 2025 05:08 AM
Re: Sky Glass freezing on Ethernet connection
I do not have Sky glass, cannot offer any solution but I have read/ listened to you vent 😉
Maybe wean yourself away from Glass viewing subscriptions.
Assuming that the picture and sound is fine on the Glass TV itself you might want to try using a streaming device in a HDMI port.
If you have a Roku, Firestick etc use that and give Now TV a 30 day trial with say Entertainment and Ultra Boost to see how it performs and if it might be a solution.
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £34 pm (till April 2026)
1000/115 FTTP (Aquiss) to Zyxel DX3301
3 x Asus XT9s + + RT-AC58U V3 for WiFi (AP mode)
65" Samsung S92C OLED TV
C430 Samsung soundbar with subwoofer
6 other streaming TVs
43+ network connected devices
Message posted on 15 Nov 2025 07:02 AM - last edited: 15 Nov 2025 07:37 AM
Struggling a bit from your post to completely understand what you have done or all Sky have asked you to do.
Do understand your frustrations though.
It can be hard sometimes to troubleshoot local network issues or any other household interference (especially when using a wifi connection).
The Ethernet port on Sky Stream, like Smart TVs is restricted to 100Mbps.
You will, as you see get around 70Mbps to 90Mbps from the ethernet port on the Sky Stream.
That though is plenty enough and should give you a reliable Sky Stream experience.
You mention 'Wi-Fi off'.
Is this as you are using ethernet on your Sky Glass TV, that you have been into the Glass TV settings and turned wifi off there.
Try making this change if you have not or if you have it already off toggle it the setting on and off.
Then do a settings restart to ensure the option is set correctly:
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TV puck will perform a few reboots and a cache clear up.
It will take a few minutes to complete.
A few other things.
Is your ethernet cable from your Sky Glass TV connected straight to your broadband router?
Or is it connected to a mesh system or connected to an unmanaged ethernet switch?
As long as you use a cat5e or cat 6 cable, there is no need to use the Sky supplied one (the Sky one is a cat5e cable).
No need to use a cat 7 cable or higher, it will not offer you any general advantage for the Glass TV.
One thing to try if it's just happening once in a while, rather than many times a day.
Do a settings restart, as about once a week.
Think of it like restarting your PC, tablet or smartphone occasionally when they become a bit laggy.
I have always done the settings restart for both my Sky Stream pucks (connected on wifi) in the 20+ months I have had them and never suffered from any local network issues with my pucks. Not sure if it does cure any issues, but causes no harm. The settings restart does also do some background cache cleanup, that can build up with the many menu, account and app use case. And may be causing your Sky Glass TV to lag a little and cause some software/hardware glitches.
I have suggested this for others I know that have Sky Glass TVs and pucks and they too have a reliable wifi experience. I know of none I personally know ( apart from customers mentioning they do on here) who run their Sky Glass TVs or pucks on ethernet, as they all have setup a reliable and considered an interference reduction local network environment.
Just for clarity.
When you had your Sky Glass TV on wifi, what did the Netflix app speed test on your Glass TV shows as the speed?
Message posted on 15 Nov 2025 08:31 AM
Thank you for your reply, I appreciate it. Sorry yes it was a little rant!
WiFi off, I meant on the tv itself. I have followed the instructions you provided previously (sky have had me send photos several times of the tv showing WiFi off). and the WiFi option on the tv has been off for a while now.
The cable I'm using currently is a cat 5e, I had a cat 8 on the tv for a while earlier this year but was asked to go back to a cat 5e, it still freezes.
They say my internet is unstable but my internet provider says I haven't had any drop outs. When I do use the WiFi option I get speeds of between 90 and 150
Additionally, I have a puck in another room which runs on the WiFi since the beginning and it hasn't frozen once.
Thank you for the advice about resetting settings once a week. We do have to reset the tv once a week when it freezes but I could try to reset as a preventative instead.
Message posted on 15 Nov 2025 08:36 AM
Hi, thank you for your reply, I appreciate you reading through 😁
The picture quality and sound are great, but the tv has frozen whilst using Apple, Netflix, sky sports, bbc 2, playing PlayStation (which was connected by Ethernet too.
thank you for your suggestion though, I have a fire stick so it might be worth giving that a go
Message posted on 15 Nov 2025 08:48 AM
Your Sky Glass TV puck will perform a few reboots and a cache clear up.It will take a few minutes to complete.
A few other things.
Just for clarity.
Forgot to add, the tv is connected directly to the router,
