Discussion topic: Sky Glass - freezing for about 2 seconds on BBC1 (live) and Channel 4 (1st advert only)
This message was authored by: daveredski
Sky Glass (Sky OS 1.3, Build QS037.026.00P, Hardware Model LT043-f1-ant) - after suspecting a WiFi issue, it's now using Ethernet (VodaFone Full Fibre 150) - the problem is that the 1st advert on Channel 4 pauses (every time) for about 2 seconds. The same has started to happen on BBC1 (live, not on iPlayer) and it's random, the screen freezes for a second or two - probably once an hour.
Avatar for daveredski
Level 2 icon
Re: Sky Glass - freezing for about 2 seconds on BBC1 (live) and Channel 4 (1st advert only)
No one got any thoughts?
The advert thing doesn't happen if the 1st thing in a break is an add for another programme, it's the 1st commercial advert where it stalls.
