Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 19 Sep 2024 06:51 PM
Re: Sky Glass Power up Issues 19-9-24
I bought this Sky Glass two days ago, after 20 years of having no TV in the house. Well, at least now I know that I didn't break the set! I can live without televison in my life until it gets fixed. If it had been the dishwasher that was broken I would be hyperventilating right now 😄
Message posted on 19 Sep 2024 06:52 PM
Re: Sky Puck & Sky Glass Power up issues 19-9-24
Same issues here won't power up at all been this way for a couple of hours now, better sort itself out the the football later
Just writing here to inform you that it's the same in Italy! I was looking for updates on this technical issue and I found the discussion, so I decided to let you know that this is not limited to UK!
If ever there was a good reason not to buy Glass or Stream...
Ofcom won't help - it regulates content, not the technology on which you view it. You need trading standards ... GOOOD LUCK!
My sky glass 65” tv won’t turn on the LED on the front is dimming and getting bright
My sky glass 65" tv won't turn on I've rebooted it it's done it's downloading then it goes back to the same the red LED light on the tv dims and gets bright continuously and the screen is black
Re: Stream puck won't turn on
@Gary7067 wrote:I am having the same issue. Can I ask what number you called to get support on this matter?
You won't get support to resolve when it's a known issue that is being investigated.
Just check the Skys service checker for updates of the outage.
Message posted on 19 Sep 2024 06:53 PM
Sky Glass TV won’t turn on after software update
Sky glass TV keeps updating software then turns off again??
Message posted on 19 Sep 2024 06:54 PM
@Kerrie1978 wrote:For the price they charge they should have fixed it already. I've had nothing but pro lems with sky. I think the best option would be to leave sky and and go with a different provider.
What will you do when your new provider has an outage, will you then change again to someone new?
Sky glass won't turn on and light keeps flashing
Message posted on 19 Sep 2024 06:55 PM
Hahaha that made me smile
@Lawrence+cope wrote:If ever there was a good reason not to buy Glass or Stream...
All modern technology based platforms will have major outages at times, it's practically unavoidable in the current age.
Message posted on 19 Sep 2024 06:55 PM - last edited: 19 Sep 2024 07:05 PM
As everything is centralised with Comcast that's not surprising it's affecting other countries. Germany is affected also.
I didn't have a choice. They wouldn't upgrade me to Sky Q - company's orders
What a bloody nightmare I have reset and reset and reset nothing joke 1 hr wait on phone crazy
