4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Chelsea91 This message was authored by: Chelsea91
Re: Sky Glass Power up Issues 19-9-24
I have tried this its not working on mine so frustrating
This message was authored by Misha69 This message was authored by: Misha69
Sky stream issues
Switch off the Sky Stream puck at the mains plug socket.
2. Press and hold the Standby button on the bottom of the Sky Stream puck.
3. Keeping your finger on the button (underneath the puck), switch the power back on at the mains and wait until you see the LED lights flash amber then green, then remove your finger.
4. Let the Sky Stream puck complete the recovery process. This can take up to 15 minutes (may depend on your broadband speed).
5. Switch the Sky Stream puck back on follow screen instructions
This message was authored by mark9 This message was authored by: mark9
@Chelsea91
The TV will tell you the activation code then just sign in to sky website with your sky I'd www.sky.com/activate
My email is not linked to my sky glass account i have had this 3 years and there still not able to link it up so i hold no hope my tv is going to work again
This message was authored by Pam+savage This message was authored by: Pam+savage
I can't turn tv on to do anything
This message was authored by ValerieGrace This message was authored by: ValerieGrace
Sky glass TV not turning on
Seen there is a problem for lots of users
Update please?
I  have done all that stillnothing .
This message was authored by Sarah10000 This message was authored by: Sarah10000
Puck reboot (post the sky firmware issue) reverts to 'press 4 & 6' on remote
Hiya - I've been trying to reboot my 2 pucks after yesterday's issues. One works fine - managed to reboot it and re-activate it. The other one keeps going to the 'press 4 & 6 on your remote' screen, but refuses to do anything else.
I can't attach it to an ethernet cable and try that route (no cables available - I'm with Starlink)
I've tried the reboot several times and this has failed. I've also switched it off at the wall for 15 minutes and retried the reboot and no dice.
I also tried resetting the remote (eg pressing 7 & 9 etc) and ditto.
I suspect that this puck has gone to the puck graveyard in the Sky but does anyone have any magic tips to revive it? Thanks!
This message was authored by Jonathanphillip This message was authored by: Jonathanphillip
Re: Sky Puck & Sky Glass Power up issues 19-9-24
Same here just won't turn on the sky logo flashes up now again then still nothing and even the puck wont turn on either just dead
This message was authored by JEREMY68 This message was authored by: JEREMY68
PUCK STILL WONT BOOT UP,sky logo comes on then powers off.nothing but problems since i switched to stream
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@PESKYWAABBIT wrote:
And have to manually log in to all your apps again I assume.
Hassle.
@PESKYWAABBIT
That wasn't the case for me, after the restart all my apps were as they were.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
This message was authored by Ljp2 This message was authored by: Ljp2
Sky glass still not working
Sky glass still not working since yesterday
This message was authored by PESKYWAABBIT This message was authored by: PESKYWAABBIT
Re: I presume that I will not be charged for this service since Sky Glass is not functioning.
@Darminder1 "I presume that I will not be charged for this service since Sky Glass is not functioning."
Yeah I feel the same too.
It's not like just leaving the Puck alone will automatically solve the issue, we're all having to completely reset the puck, setup and readd all our apps and sign-in information again from scratch, becoming our own technical support.
Hassle.
Hassle we don't need.
Hassle we don't pay for.
Only had Sky for 3 weeks, is this what it's going to be like, how often do things like this happen with the Sky platform?
Mine still isn't working either.
This message was authored by Natalie823 This message was authored by: Natalie823
My 60" glass tv isn't turning on and at all been like this since 6am
Locked
