Discussion topic: Sky Glass Air
This message was authored by: 2muchTV
Re: Sky Glass Air
In my opinion the price of the 65"  Air is quite competitive 👍
Just looked at Argos and they have a similar spec'd TVs for similar money, however, Argos are selling a 2023  TCL for £600 but comes with a 144Hz screen which should be better for gaming and watching F1.
Sky Stream
1000/115 FTTP (Aquiss) to Zyxel DX3301
3 x Asus XT9s + 2 x RT-AC58U V3 for WiFi (AP mode)
65" Samsung S92C OLED TV
C430 Samsung soundbar with subwoofer
6 other streaming TVs
43+ network connected devices
Re: Sky Glass Air
[Removed]
Actually, the more I look, the less value for money Glass Air appears to be... it's main selling point is really the favourable long term 0% loan agreement for financing, and SkyOS if you're into that...
My advice - if you need a TV, do your research.
Moderator notes: Removed promotion of 3rd party services.
This message was authored by: Reevo87
Sky Glass Air
Currently have Sky Glass Gen2 downstairs in the living room and 1x puck through a TV up in the bedroom which is the multiroom option.
if I wanted to replace the Puck with a new Glass Air TV would I need to pay for a new entire subscription? I would be looking at replacing the Puck.
Sky Glass Gen2 65"
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Re: Sky Glass Air
@Reevo87 I think all you would need is the Whole Home Subscription. I'm sure Sky would advise you if you called them.
Re: Sky Glass Air
Is that the subscription that is £10 which is effectively multiroom? So potentially just the cost of the TV?
Sky Glass Gen2 65"
Re: Sky Glass Air
@Reevo87 I think so. People do have more than one Glass TV so they have the Whole Home Subscription too (which is showing as £8 extra per month for me at the moment on the Sky deals page but I don't need it, I only have one TV in my home!)
This message was authored by: Jporch316
Re: Sky Glass Air
Yes the whole home subscription you currently (must) have to allow the use of a glass tv and puck would cover you for  maximum 6 pucks and 3 glass TVs
no need to return the puck ..... try and use it in a different room or keep it as a backup in case a tv goes down
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
