Discussion topic: Sky Glass Air or Sky Gen2
Message posted on 01 Jul 2025 12:33 PM
Re: Sky Glass Air or Sky Gen2
Oh ok, thank you!
Message posted on 01 Jul 2025 12:34 PM
Any ideas on price for this?
Message posted on 01 Jul 2025 12:38 PM - last edited: 01 Jul 2025 12:40 PM
Message posted on 01 Jul 2025 12:39 PM
Sorry - yes, whole home. Thank you!
Message posted on 01 Jul 2025 12:42 PM
@NJH wrote:Sorry - yes, whole home. Thank you!
Whole Home is £15 per month.
Message posted on 01 Jul 2025 12:43 PM
@MarkGoldsmith - thank you!
@Anonymous - thank you for your help!
Message posted on 01 Jul 2025 12:46 PM
@NJH No problem. If you look online at sky.com in the Glass section, you can do a side by side comparison of the Glass and Air, which includes the dimensions of each, which might be helpful in you deciding on the size of the TV.
Message posted on 01 Jul 2025 12:56 PM
@Anonymous - thank you I will do that. Really great to have some help for a very non-tech person!
Message posted on 01 Jul 2025 12:59 PM
@MarkGoldsmith - one last thing! This puck you are talking about - my other tv is flatish on the wall, where does it plug in, bearing in mind I wont be able to take the tv down!
Message posted on 01 Jul 2025 03:12 PM
@NJH wrote:@MarkGoldsmith - one last thing! This puck you are talking about - my other tv is flatish on the wall, where does it plug in, bearing in mind I wont be able to take the tv down!
The puck connects to one of the HDMI ports on your TV; however, you will need somewhere to place the puck (it's a small box). If you have the TV wall-mounted and don't have a shelf or cabinet close enough to the TV to use an HDMI cable, then the puck won't work for you.
Message posted on 01 Jul 2025 04:01 PM
@MarkGoldsmith - perfect, my current mini is behind the wallmounted tv anyway. Thank you so much for all your help!
Message posted on 01 Jul 2025 04:24 PM - last edited: 01 Jul 2025 04:26 PM
It's worth noting it's not recommended having the stream puck tucked behind a wall mounted TV, it's advised that the puck is out in the open.
Message posted on 01 Jul 2025 04:41 PM
@MarkGoldsmith - oh, ok, thank you for letting me know😊
Message posted on 01 Jul 2025 10:48 PM
If it's for your living room or it's going to be your main tele I would go for the Gen2, the Air is ideal for a bedroom, I have both but I favour the Gen2
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
