2
This discussion topic has been answered Discussion topic: Sky Glass 43” wall mount
This message was authored by: Marzipan10
Hi, does anyone have a wall mount they'd like to sell? I wrongly assumed I could order one after purchasing!
Hope someone can help or suggest a suitable alternative bracket.
Thank you
This message was authored by: Anonymous Answer
Re: Sky Glass 43” wall mount
The Glass is VESA compatible. Just make sure you order one that can support its weight.
Avatar for Marzipan10
Thank you for your help😁
