Discussion topic: Require wall brackets for sky glass
This message was authored by: Jude36
We have misplaced the wall brackets when we purchased the tv
how can we get hold of some please
Re: Require wall brackets for sky glass
Hi @Jude36
See buy spare parts here: https://www.sky.com/help/articles/sky-glass-tv-repairs
However sky glass will work with any VESA wall mount as long as it is rated for the weight.
MikeAlanR
@Jude36
If it's a Sky Glass Gen 1 then the wall plate is a component of the tabletop stand.
Avatar for Jude36
Is it -thank you very much
@Jude36
@Jude36
Note that you do need either the supplied spacers or some of equivalent thickness to have the plate the correct distance out from the wall for the television to seat correctly (and safely)
The original circular black Sky-supplied spacers would have arrived in a brown paper packet with the rest of the hardware.
