Discussion topic: Poor picture and sound
This message was authored by CraigMF This message was authored by: CraigMF
We seem to be dealing with sporadic pixelated picture and out of sync sound with our sky glass.
We have a 50mb wired connection which used to stream via Netflix perfectly before we got sky glass.
We feel we made a mistake switching to the sky glass service.
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Poor picture and sound
Hi @CraigMF
What speed do you get if you do a Netflix speed test via the app?
Open Netflix on Glass
From the Netflix homescreen, go left to open the menu.
From the bottom of the menu, go right and select Get Help.
Select Check your Network.
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by SlenderRobert This message was authored by: SlenderRobert
If you feel you've made a mistake switching to Glass then you can return it free of charge for a full refund if you're within 31 days of activation.
If you've had it longer than that then you'll have to demonstrate to Sky that it is not functioning as advertised.
