Discussion topic: Picture pixelating on sky glass and you tube freezing. Broadband speed more than adequate.
Message posted on 28 Jul 2024 10:50 AM
Message posted on 28 Jul 2024 02:31 PM
Re: Picture pixelating on sky glass and you tube freezing. Broadband speed more than adequate.
@GaryH1973 wrote:Picture pixelating on sky glass and you tube freezing. Broadband speed more than adequate.
What is the broadband speed that's actually reaching the Glass TV though?
If you're connecting via WiFi then there can be all sorts of interference which can affect the speed and quality of the connection. To find out the actual speed being received you need to run the speed test within the Netflix app on the Glass TV. Open it and navigate to the get help menu. Run the network check in there and see what the result is.
Message posted on 28 Jul 2024 06:00 PM
134 and wired
Message posted on 28 Jul 2024 11:03 PM
@GaryH1973 wrote:134 and wired
Make sure WiFi is turned off on the network settings. It stupidly will default to this, even with an Ethernet cable attached.
If it still doesn't work after a reboot of the TV you're best to ring Sky for further troubleshooting.
Message posted on 29 Jul 2024 07:49 AM
Try it on WiFi ........
