Discussion topic: PS5 on Sky Glass (65inch)
This message was authored by: Char46
Can anyone confirm the PS5 works on a Sky glass 65inch TV. We have read many conflicting comments and have even called Sky and they couldn't give us a definite answer. Thanks!
This message was authored by: CoffeeDrinker
Re: PS5 on Sky Glass (65inch)
PS5 does work on Glass. It will do both 30 & 60Hz/fps 4K with HDR with low latency. It won't do 120Hz or variable refresh rate though. Glass is far from the ideal gaming TV but will happily do th3 basics well.
are there any specific concerns you have with PS5/compatibility?
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
This message was authored by: david+john
It works perfectly on my sky glass 65in never had a problem with ps5
This message was authored by: Jason2113
Yes, it does.  i have been using it for past over 1 year
This message was authored by: Reevo87
Mine works but finding it lags ever so slightly, anyway to fix this please?
Sky Glass Gen2 65"
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Are you coming from a TV with a higher refresh rate? Going from 120hz will definitely feel laggy to your eyes.
No my LG TV had 60hz as well
Sky Glass Gen2 65"
I have read places people connecting via an Ethernet cable, not sure what difference if any that would make though, some putting it down to WiFi connection
Sky Glass Gen2 65"
Are you describing the image being jumpy or actually the game being laggy? Like if you were playing call of duty perhaps the players are moving around inconsistently or you can't walk properly.
If it's the latter then it's not a TV issue but a PS5 issue, and an Ethernet into the back of the PS5 could help.
Sorry I'd describe it as being more jumpy, the games are still playable etc.
Ethernet cable direct from the PlayStation into the router? And keep the sky glass tv connected via WiFi only?
Sky Glass Gen2 65"
Yeah unless you wanted to Ethernet them both to the router. What I'm describing is that if it's the gameplay being laggy, it's a PS5 issue but if it's an input delay it might be a TV issue.
This is one of those things that's super hard to describe and understand without seeing it in person, so sorry if I'm being unclear or not understanding.
This message was authored by: Jporch316
Yes the WiFi on the tv will have no bearing on the ps5
