Discussion topic: Other TVs in house have no signal after installation of sky glass
This message was authored by LcB This message was authored by: LcB
Sky glass installed now other TVs don't work,no signal
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Other TVs in house have no signal after installation of sky glass
@LcB what exactly doesn't work on your other TVs? Normal DTT channels?, streaming apps?
If you are actively using your Sky Glass, it will eat up internet bandwidth so if others in your household are also trying to stream ( depending on the speed of your internet) it could affect not only them streaming but also the Sky Glass working correctly.
Sky Stream and Sky Broadband customer
LcB
Hi , they just say no signal check antenna
If your Sky Glass is connected to the internet, its not using your traditional TV ariel so therefore cannot really be having any affect on your other TVs.
I'm assuming your Sky Glass is indeed just connected to the internet and your don't have the ariel plugged into it. (not that the Sky Glass would be using the the DTT signal if the internet is setup on it).
LcB
aRe: Other TVs in house have no signal after installation of sky glass
Hi thats what we thought but clearly a problem we'll need to check out , thanks a lot for replying much appreciated 👍
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
What did the Sky Glass TV replace?
Did you do the installation?
LcB
Hi it replaced a sky plus box yes we installed it ourselves
Did you have an aerial lead going into the Sky+ box and another coming out and being passed to the other TVs?
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
If you  now want sky on your  other tvs  in the house, then you  will  need the whole home, and then to buy a streaming  puck for each tv,
OR if you just Sky's subscription channels and the TVs are Smart use Sky's budget service NOWTV😉
The service that just works😂
@LcB when you disconnected the Sky+ box there were probably two coax leads one of which camr from the aerial on the roof the second went to the other TVs in your home. Connect the two together and the aerial signal should be restored to your other TVs. However you will no longer see Sky programmes on those TVs as you could with your old system as aerial passthrough stopped being a system 8 years ago on new Sky kit.
