Discussion topic: Not happy with sky glass sound
Message posted on 18 Aug 2025 09:36 PM
Just purchased sky glass and I'm not happy with the sound. It's not as good as my sky soundbox, is there anything I can do to improve it? I turned on bass boost and there was no difference.
Message posted on 18 Aug 2025 11:34 PM
Re: Not happy with sky glass sound
Hi @goldihanw
have you got a gen 2 or a glass air ?
if it's a gen 2 there should be a big difference with bass boost on
I also have enhance speech turned on
Message posted on 18 Aug 2025 11:51 PM
Gen 2. Bass boost made no difference.
Message posted on 19 Aug 2025 07:37 AM
@goldihanw wrote:Gen 2. Bass boost made no difference.
You possibly have a faulty speaker on your Glass TV. Call Sky for further troubleshooting and potential replacement.
Message posted on 19 Aug 2025 07:53 AM - last edited: 19 Aug 2025 07:56 AM
The Soundbox is considerably bigger and has more individual speaker drivers than the bar in the Glass television set.
Message posted on 19 Aug 2025 07:56 AM
I've worked out how to connect my son box now through Bluetooth. The tele and box sounded great together at first but now they don't sync. I need to decide so I get used to the sky glass tv sound or do I just use the soundbox.
Message posted on 19 Aug 2025 07:57 AM
Should have said sound box. Wish you could edit.
Message posted on 19 Aug 2025 07:59 AM - last edited: 19 Aug 2025 07:59 AM
Unfortunately Sky didn't equip the Soundbox with ARC and Glass doesn't have optical audio output, so more typical cabled connection isn't directly available.
