4
Discussion topic: No signal. Check the external input or select another input using the input button
This message was authored by Sue1269 This message was authored by: Sue1269
Help please!! My sky stream is showing the above message. Have changed HDMI Ports, rebooted the sky stream puck and controller, but nothing. Seems as though the puck is not connected to broadband??
Sue1269
This message was authored by Sue1269 This message was authored by: Sue1269 Answer
Re: No signal. Check the external input or select another input using the input button
All sorted now. It was a faulty HDMI cable.
This message was authored by Addie15 This message was authored by: Addie15
Posted by a Sky employee
Worth noting that's a message generated by the television set, not the puck.
The television is telling you it can't find a signal coming from the puck.
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
So that seems to indicate the Puck has failed and is not generating any output?
Exiled in HH
Sue1269
