2
This discussion topic has been answered Discussion topic: Network connection issue
This message was authored by: RohitAgarwal
I need MAC address to connect my WiFi with sky stream but i don't how to find the mac address. Can you please help me to find it . I bought the sky stream from last 4 days but can't enjoy it atm because of this problem. Please help me asap
This message was authored by: mikealanr Answer
Re: Network connection issue
@RohitAgarwal
You go settings> system management > system info
You will see Mac address WiFi and ethernet.
This however will only be available once the puck has been activated, you may need to connect your puck to a 4g hotspot, get the info and then reset the network connection in settings > network > advanced. And the join to your WiFi.
MikeAlanR
@RohitAgarwal
MikeAlanR
Avatar for RohitAgarwal
Yeah it's work now . Thanks ☺️
