Discussion topic: My sound quality is considerably lacking
This message was authored by: Lellyd1
The sound quality is considerably lacking. The reality of the television is that it is basically just a very large and expensive monitor screen! For which I wouldn't have a use if I didn't prescribe to sky
Moderator note: subject of thread updated to better reflect the conversation
Re: My sound quality is considerably lacking
Can you elaborate? The sound from Glass TVs is generally considered better than you would get from a standard panel TV/
This message was authored by: KevNewMedia
Posted by a Sky employee
Hi @Lellyd1
Welcome to the Sky Community.
Do you have a Gen 1 or Gen 2 Sky Glass TV?  You can check by providing us with the hardware model number from settings > system management
Kev
Community Manager
Avatar for Lellyd1
  • IP061-ef so I don't know if gen 1 or 2
This message was authored by: Carnoch04
Gen 2 has only been available for a couple of weeks.
Sky Stream since launch with Philips 55" Mini LED. Sky Glass Gen 2 55" now added.
