Discussion topic: My sky store will not work it says cannot login and code 0300
Message posted on 23 Jul 2024 11:56 AM
My sky store says this everything
We're having problems signing in codeb0300
Message posted on 23 Jul 2024 02:20 PM - last edited: 23 Jul 2024 02:29 PM
Re: My sky store will not work it says cannot login and code 0300
Sky Store on Sky Glass and Sky Stream
If it's your first login or if you previously signed out or if you done a factory reset
To login into Sky Store on Sky Glass/Sky Stream you need to do the following
Sky Glass/Sky Stream home screen
Click Playlist
Then scroll with remote to the bottom and select Sky Store Purchases
Log into your Sky Store account from here and you should see your content
Then Go back to the Sky Store App and you should be able to see your library.
