Discussion topic: My sky glass is saying technical fault, try again later, when it does this I assume I still pay in
This message was authored by: tina012
My sky glass keeps saying technical fault,  try again later,  they still expect me to pay my bill.
Re: My sky glass is saying technical fault, try again later, when it does this I assume I still pa
@tina012 This is quite a common issue and is usually resolved by a reboot of your Glass TV.  SImply switch it off at the plug socket for a minute or so and then switch it back on again.  It takes about a minute to reboot.
Hopefully that will resolve the issue but if not then try rebooting your router.
With my Glass TV I found it was more stable when I turned OFF all the gimmicky options in the Settings > Start up & standby menu with the exception of the Networked Standby Mode which should be turned ON.
This message was authored by: coolmerc
It's down to sky, they are testing firmware on the public again, it was the same about a year ago until they rolled out some firmware that worked, this is the first I have seen regarding the slowness and messages such as “please wait for the programme to load” and "There is a technical fault with this programme, please try later” for about a year when I used to have the problem. It's a dam disgrace, we pay for sky service and this is what we get, they want to get some decent firmware programmers and do lots of testing before releasing it on the public!! The problems are happening not only on sky glass but my 3 sky pucks as well even when connected via ethernet, my line speed is 150mbps which is more than enough.
This message was authored by: Drewedgar
I'm having the same issue. I have to switch the TV off at the wall almost every time I switch channels. As others have said, same problem a year ago, although it seems worse this time.
Can I ask which ISP you are using? I am using Youfibre, I am curious to see if you have the same  provider.
@coolmerc  I'm also with YouFibre
There's a few people local to me who are having the same issue with Sky and YouFibre
I opened a ticket with Youfibre who then contacted Sky, that was over a week ago, Youfibre has contacted me a few times to see if anything had changed, not sure whats happening behind the scene's or who is doing what to fix it.. I originally contacted Sky who said they would call me back but never did, typical of Sky.
Avatar for tina012
I find it very annoying as it can happen any time of the day. With what we pay for the service I expect almost 100%, they never reduce our bills at all. Sometimes it goes on for a while.
Avatar for tina012
If you mean broadband provider I have sky,  sorry I'm not very technical minded.
I was in contact with one of the YouFibre support guys who liased with Sky to resolve this issue, so everyone who had the problem described in this thread who's ISP was with YouFibre should now be fixed. Apparently YouFibre was using a new set of IP addresses that Sky had a problem with. Many thanks to Mark from YouFibre who worked diligently and kept in contact with me almost every day untill a fix was applied in their systems.
This message was authored by: patricia41
  • I'm continually having all these issues and having to reboot regularly and I'm with BT and have great band width. Its so frustrating. 😤
first line of contact would be [removed] at sky support but I would contact your ISP to check things aswell.
moderator notes: removed inappropriate language
This message was authored by: Andy+Sewell
Mine too. It's irritating. I wish I could go back to the old dish and black box.  Sky Glass has been nothing it trouble. Riddled with issues.  Now Gen 2 is out. I'm left with this crock of **bleep**.
This message was authored by: rv291066
My work around is to go to TV guide & choose NEWS... then BBC news... then just use the down button to go to Sky News
