Discussion topic: Losing connection
This message was authored by: OGBO
Losing connection
The TV screen seems to be going off and showing black screen several
timea a day. Whilst it's only distrusted for about 10 seconds and then it comes back on, WHY is this happening?
Re: Losing connection
@OGBO How are you connected? WiFi or Ethernet? If by WiFi, try using ethernet as it gives a more stable connection and if you connect by ethernet make sure you turn WiFi off in the settings.
This message was authored by: Dave1234567891
This is also happening to me 900mb full fibre, connected by Ethernet. Yet another sky puck problem. @@Sky let me out of my contract so I can go back to Virgin. Worth the extra for no lip sync issues, no pictures drop out. Or even just fix the issues!!
Avatar for OGBO
Unfortunately Ethernet is not an option for us but thanks for response
Avatar for OGBO
It's a nightmare especially the price being charged for the services.
I've been with Sky for years and don't really want to switch provider BUT maybe something I need to look into.
problem being is I have Sky glass and not sure what would happen if I left!?
@OGBO You can have any ISP to run Glass/Stream. I'm with Vodafone and have no issues with my internet with them (unlike Sky with whom I had real speed issues, which did mean I could terminate the contract early without penalty).
If you can't run ethernet to Glass, one option is to buy a pair of Powerline adapters and two ethernet cables. Plug one adapter in by your router and then run an ethernet cable from the router to adapter. Plug the other in near your Glass and run the other ethernet cable from adapter to Glass. Turn WiFi off in settings.
It really does make a difference to the stability of your connection. When I first got Glass in Dec 2021 I had issues with connection for the first week on WiFi, I went to ethernet and have barely had a connection issue since.
You basically own your Glass, so if you cancelled your TV viewing, you would still have to pay any outstanding loan amount each month until it's paid off. The way you use the Glass would change, as outlined here:
https://www.sky.com/help/articles/sky-glass-without-a-subscription
This message was authored by: Jporch316
The Ethernet adapter is 100mb on the puck. Try turning off wifi in the settings if you are using Ethernet
or try switching to WiFi
Switched to Ethernet (at skys recommendation) from WiFi, didn't solve the issue. 100mbps should be plenty, it's just a joke and Sky don't care.
