4
This discussion topic has been answered Discussion topic: How to connect sky glass to alexa
This message was authored by: AnnaT85
Hi i just want to know how to connect Alexa to my sky glass
This message was authored by: MarkGoldsmith Answer
Re: How to connect sky glass to alexa
You can't as Sky has no officially supported Glass/Stream skill for Alexa
This message was authored by: Y3lto
My echo is connected to my sky glass. I dont think it can do anything, yet, bar let the tv play through it ( not that anyone would) but it can be connected..
This message was authored by: CelinaMatt319
My brother used this DIY setup to connect his Sky glass to alexa , i am not sure how good it works , but it did definitely works .Using Alexa enabled firestick connectng it to sky glass .The Sky Skill on Alexa definitely don't work .
Maybe this will be helpful - https://amazonalexatip.com/how-to-connect-sky-glass-to-alexa/
This message was authored by: Jporch316
I have a Tapo smart plug which I plug the glass into ..... I have added the Tapo skill to Alexa .. if it ever needs a full power cycle I just say "Alexa sky glass off" wait a few minutes then "Alexa sky glass on"
I would say all other voice commands to control the tv are built into the sky glass
the only other reason for connecting would be to use the Alexa as speakers although the in built sound is much better in my opinion
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
