7
This discussion topic has been answered Discussion topic: How do I turn OFF Glance Motion on the Sky Glass gen 2 TV and KEEP enhanced features ON?
This message was authored by: MichaeWlG
It seems this is impossible, as switching off Glance Motion, also switches off Enhanced Features. So why have this impossible option?
55" Sky Glass Generation 2 TV
Re: How do I turn OFF Glance Motion on the Sky Glass gen 2 TV and KEEP enhanced features ON?
@MichaeWlG
I'm saying the items/features listed in the ' Sky Glass Gen 2 Enhanced experience ' marketing text which you found have nothing to do with the 'Enhanced experience' menu in the operating system, or the post initialisation selection (which just sets the menu state)
All of the 'enhancements' listed in the marketing text are intrinsic to the Gen 2 hardware release when compared with the model from four years earlier, and are unaffected by either the menu setting or the option chosen during set-up.
Unfortunately the 'Enhanced experience' menu has always been an unpleasant mess and some of the terminology, particularly 'glance motion', is just ludicrous ; )
Hi @MichaeWlG
See: https://www.sky.com/help/articles/sky-glass-tv-turning-on-off-glance-motion-technology
Enhanced experience comprises of Networked standby mode, wake by motion detection and auto standby using motion.
While the enhanced experience switch turns off when you switch off wake using motion you can enable these other features individually. However you can not have glance motion ON when wake using motion OFF.
MikeAlanR
Avatar for MichaeWlG
Level 4 icon
Thanks for your reply Mike, but how do I achieve this?  "While the enhanced experience switch turns off when you switch off wake using motion you can enable these other features individually".
I ask, as whenever I switch off "Wake using motion", it automatically swicthes off "Enhanced experience".
According to Sky, the Enhanced experience consists of these:-  The Sky Glass Gen 2 Enhanced experience includes a brighter 4K Quantum Dot screen with improved contrast and viewing angles, a re-engineered seven-speaker Dolby Atmos sound system with dual subwoofers for deeper, richer sound, and an updated Sky OS interface for faster navigation and personalized features like Playlists.
So if I switch off "Wake using Motion", I lose all the benefits of the above Enhanced experience, as that also switches off?
So, how do I KEEP the Enhanced experience features, whilst disabling Wake using Motion?
Michael
Hi @MichaeWlG
In don't believe you loose those functions. I think the term enhanced has been used more than once in the marketing which is causing some confusion for you.
Those features are controlled by a separate menu and via the relevant subscription. The menu in startup and standby lists the features enabled or disabled by switchin on or off that feature switch as per the article I linked to.
MikeAlanR
Level 4 icon
Thanks Mike, but where do I find:-  "Those features are controlled by a separate menu and via the relevant subscription".
More specifically the separate menu?
Michael
@MichaeWlG
As @mikealanr indicates, you appear to have found a piece of marketing blurb (possibly AI-generated) about 'enhancements' of the Gen 2 (2025) Glass release relative to the Gen 1 (2021) version, and are confusing this with the very specific and limited set of hardware features controlled by the 'Enhanced experience' menu in the Glass operating system: these are entirely unrelated and any similarity is coincidental.
Level 4 icon
Thanks Tim, so the setting Use Enhanced Experience that appears when you initialise the Glass TV, has no relation to the Enhanced experience in the Settings Menu?
Confused or wot? Even more confusing is, why have two sets of options that will turn each other off or on?
Michael
@MichaeWlG
