2
This discussion topic has been answered Discussion topic: How do I get sky glass remote to control volume on my Bose 500 soundbar through arc hdmi,
This message was authored by: Denno530
How do I get sky glass remote to control volume on my Bose 500 soundbar through arc hdmi,, the soundbar is turned on when to starts up but I have to use Bose remote to do volume
Avatar for Denno530
This message was authored by: Denno530 Answer
Re: How do I get sky glass remote to control volume on my Bose 500 soundbar through arc hdmi,
Hi
I removed the bar and reset back to factory settings then started from scratch , it worked ok and still is , hope this works for you
This message was authored by: Rogers28
Hi, did you manage to get an answer to your question? I have the same issue.
Avatar for Denno530
Hi
