Discussion topic: Connect led strip lights to sky glass
This message was authored by: davecspurs
Connect led strip lights to sky glass tv
Re: Connect led strip lights to sky glass
@davecspurs  Are you asking a question or making a statement?
@davecspurs
You can stick them on to the enclosure, certainly.  What you can't expect is power from the USB-C port, which is intended only for the Live camera.
 You also won't get any 'interaction' from a Glass HDMI port: only colour-change strips with their own camera for screen detection will work with Glass.
This message was authored by: Wee+kaz
hi i am trying to install govee t1 strip lights to my sky glass but all i am getting a solid red colour on my strip lights .
See the post immediately before yours.
does that mean that the govee t1 backlight led strips wont work on my tv?
This message was authored by: Padam_Padam
Have you installed the led strip correctly, with the camera looking down at the screen? You can't power anything using the USB-C port on Glass so need to connect the Govee control box to the mains.
the govee box is powered into the mains. it is working on youtube on a floating colour video but its staying stuck on red on movies.
This message was authored by: Daddydaz14
The only USB c port in my house is on my sky glass and I can charge my watch with it so the c port must provide some power functions.
@Daddydaz14 it does but it's onlt recommended that you uyse the Sky Live camera in it as thats what its there for
This message was authored by: JackMarsh
Hi all, what would be your best recommendation for ambient tv lighting for a sky glass ?
