23 Mar 2023 11:02 PM
Could someone give me the correct settings in sound for my setup please as i have googled it and confused myself, which is annoying as I'm usually ok with this kind if thing (I'm putting it down to lack of sleep)
In one room I have sky stream (Ethernet via power line) with a Samsung S95B, i have it connected to a Sonos Arc with a Sonos mini sub and two Sonos One SL surround speakers.
In the other room I have sky stream (Ethernet via power line) connected to a Samsung QN90B with a Sonos Beam 2
On stream I have UHD & Atmos add on's.
So my question is, for the very best sound results should I choose in stream sound settings, Auto, Dolby Digital Plus or pass through for each set up ?
TIA
24 Mar 2023 07:27 AM
I no longer have Stream, but I did have it for about 3-4 months. However, I did have most of the Sonos gear you've listed connected to Stream at the time. I found the best sound setting on the Stream was Auto. In fact, if I selected pass through on the Stream settings I got no sound at all. My TV is an LG and the sound settings are set to pass-through there. With those settings everything seemed to sound great, along with the excellent Stream picture quality.
24 Mar 2023 07:39 AM
As long as the HDMI handshakes between your devices are solid, Auto on the puck sound settings should send the best possible sound quality to your Sonos devices.
