Discussion topic: Cant operate sky glass as remote wont do anything. I have reset the remote, rebooted the system.
This message was authored by: KS7
Sky glass won't work. I've done absolutely everything suggested by Sky help...reconnect remote, change batteries, reboot whole system. It is still not working and I have no access to my tv at all!
Re: Cant operate sky glass as remote wont do anything. I have reset the remote, rebooted the system.
@KS7Have a look at the following remote troubleshooting guides which might help:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
