Discussion topic: Vulnerable adult needing backup power supply for router
This message was authored by: FMCR
Hello. I live in a remote rural area with no mobile signal. I'm disabled and recently widowed,  and I'm terrified of not having phone access in a power cut.
I have been told (by AgeUK) that as my service provider,  SKY should provide a 'UPS' (Uninterrupted Power Supply) battery back up, and I would like to find out how to get this sorted as soon as possible,  please?
There are frequent power cuts here, in winter. As a wheelchair user,  it's almost impossible for me to go out safely to find somewhere with a mobile signal near enough to use. Also, I am really worried that if I have a fall and have no home phone access because the WiFi is down, I'll be stranded without any way to get help. I'm VERY worried about this and very nervous. I used to be able to simply plug a basic phone into my BT phone socket even in a power cut,  and amnow regretting changing my landline to SKY. Any help would be much appreciated,  thanks!
Re: Vulnerable adult needing backup power supply for router
I assume you have Sky's internet calls. You'll need to give Sky a call about a battery backup. If you're registered with Sky Accessibility, there are a number of contact options.
https://www.skyaccessibility.sky/
