Discussion topic: Diabled remote
This message was authored by: Broderickasams
Message posted on 17 Nov 2020 10:57 AM
Diabled remote
I would like a remote controller suuitable for ise by a blind person ie. large buttons. Please
Find out more
Message posted on 17 Nov 2020 07:55 PM
Re: Diabled remote
I think the best you will get is this one:
https://www.sky.com/help/articles/accessibility-remotes
The Accessibility and Easy Grip remotes work just like our standard remotes, but they’re specifically designed to be easier to use if you’ve got limited vision or dexterity.
They have:
- Raised contour buttons with additional tactile points
- Larger and bolder button graphics
- High visibility buttons
- Shortcut buttons to quickly turn on subtitles and audio description
- A textured, easy grip design
If you’re a registered Accessibility customer, you can contact Sky for a free Sky Q Accessibility remote or Sky Easy Grip remote.
