Discussion topic: Incoming emails not going to inbox
This message was authored by: Amg43
Unable to get emails in my Inbox. They go into Bin
Re: Incoming emails not going to inbox
@Amg43
I take it you login to the Sky website to access your emails, if so check these settings:
Go to Settings (the screw icon on the right hand side) > More Settings > Filters and remove anything that you did not setup.
If you have had to make a change then logout and change your password:
https://skyid.sky.com/resetpassword/
This message was authored by: peapodX
Go to Settings (the screw icon on the right hand side) > , there is no longer a screw icon on RHS,
@peapodX yes, now under the hamburger menu and  apart from the most basic settings, everything appears to have vanished.
Edited to add: ah... it's still there on the PC/laptop version. Not android unless you use desktop mode.
