Discussion topic: zScaler Slowness Issues
This message was authored by: Yamesh
Hello!
My employer routes all my work device browsing activity via zScaler. I've noticed that the browsing experience on my Sky Broadband connection can be very poor and slow - in some cases pages don't load and require a refresh.
Looking on the forums, there seems to be a past known issue. Is this now resolved/is there anything I need to change config wise?
Avatar for Yamesh
Re: zScaler Slowness Issues
Specifically, the fix appears to be disabling MAP-T, the form for which is no longer available
This message was authored by: Me134
If it is MAP-T causing this you'd need to contact them, 150 on your landline of Sky mobile.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
