Discussion topic: wifi
Message posted on 28 Nov 2025 10:42 PM
wifi
i had an engineer come out earlier to fix a chewed cable, but the wifi keeps dipping in and out. i have checked server issues and that is fine so unsure why the box keeps needing to be restarted
Message posted on 29 Nov 2025 04:54 AM
Re: wifi
@kittyfearn
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
If you’re still having problems you may need to contact Sky again to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Message posted on 29 Nov 2025 09:41 AM
Re: wifi
@kittyfearn Was everything working well before your cable issue that was replaced and as you have not said which actual cable either a DSL connection to a OR Master phone socket, but if it was the Ethernet to a full fibre connection then that should go back straight into full operation! If it was the DSL cable you just have to leave it all alone now for the 10Day possible recovery as the DLM works it all out!
