1
This discussion topic has been answered Discussion topic: wifi
This message was authored by: cerys8
wifi
my wifi is not connecting at m - i have no wifi for 3 days! when will this issue be fixed i am
a new sky customer and i am not happy with this service provided
Re: wifi
@cerys8
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: wifi
@cerys8
