Discussion topic: Sky Broadband hub with BT Whole Home
This message was authored by: P+Heywood
Hi there - just switched from Vodafone to Sky, half the price and an extra 50Mb (from 100Mb)
I use BT Whole Home discs to cover the house, worked fine with Vodafone, with most devices around the 100Mb mark regardless of the disc they were connected to.. Since the switch I have two discs working fine (providing 150)  but the third is only providing around 20/30Mb.
Am I doing something wrong?
Re: Sky Broadband hub with BT Whole Home
@P+Heywood Not so, is the third disk in the whole home mesh seeing the others, you may just have to try a different position for that one!
Avatar for P+Heywood
It's in the same position as it always was, but it has just dropped out.... it's been rock solid until the switch to Sky... though that disc shouldn't know the provider has changed!
@P+Heywood That's correct, the mesh is controlled seperate and only Lan connected to the main unit, as you said two out off three were good, you only have to look at that one, see what the home mesh utility has to say about the mesh, you could swap two off the units about to see if gets the speed that it should have in your opinon.
