Discussion topic: wifi
Message posted on 19 Sep 2025 06:34 PM
wifi
my broadband keeps droping off its happened 4 times in the last hour and twice yesterday can anyone help
Message posted on 19 Sep 2025 06:42 PM
Re: wifi
@robhowardfeb69
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
