Discussion topic: Full fibre broadband upgrade
Message posted on 19 Sep 2025 05:17 PM
Hello
I received the equipment today but all we got is the yellow Ethernet cable.
is this correct?
thanks in advance
Message posted on 19 Sep 2025 05:21 PM
Re: Full fibre broadband upgrade
The 'conversion kit' cable links an existing Sky Broadband Hub to the Optical Network Terminal (ONT) in an FTTP circuit. If you don't currently have an ONT at the address then this is installed along with the optical cable itself.
Message posted on 19 Sep 2025 05:47 PM
Thank you. I don't have an ONT at the moment so I guess the engineer will bring one on the activation date?
Message posted on 19 Sep 2025 06:08 PM
@Treacletown yesthe engineer brings the ONT kit.
Message posted on 19 Sep 2025 06:12 PM
Yes it is
Message posted on 19 Sep 2025 06:13 PM
Thank you for confirming.
The engineer will need this when he comes to install your broadband, i had the same when i up graded to full fibre broadband
