Discussion topic: wifi slow
Message posted on 19 Nov 2025 03:46 PM
wifi slow
Have 1GB fibre just installed. Connection is slower than previously. Getting around 50-80MB download and upload on speedtest and google speedtest. Have tried restarting, moving laptop right beside router, changing cable to cat 6, changed channel in router setup. seperating 2.4GHz network from 5GHz and connecting less important devices to 2.4GHz. Still have slow speeds. Really regret "upgrading" to fibre. Was getting glitches on ping to router and dropped packets before splitting the networks. Now its just slow.
Message posted on 19 Nov 2025 04:16 PM
Re: wifi slow
@dny1 Take it you have the sky Broadband Hub that is black in colour? See link below if you are not sure!
Message posted on 19 Nov 2025 04:41 PM
Re: wifi slow
yes its black. It was new with the fibre installation
Message posted on 19 Nov 2025 05:00 PM - last edited: 19 Nov 2025 05:09 PM
Re: wifi slow
@dny1 The web interface to the sky hub will show you the sync up/down speeds that are set Maintenance/Router Status to see those, mine was 549 900 and 75 000 spaces to get through the filter, yours will be higher as on the Gig package, also if you can Ethernet test through the hub for speed, and the sky service checker will show you history 30 day's is stored but as new you will not have that yet, link below to it!
Make sure Port4 Wan connection back off the Hub to the ONT Lan connection, and everything is shared network wise, i do not have to shut off any off my wireless devices as Know and Trust the operation off them, so when i wireless speed test from my laptop hit's the 500/70 every time unless OR Network is busy with some slowdown, have NO battery saving on it, all turned off to keep the CPU tramping at max, but mains PSU connected normally keeps that at bay anyway!
Message posted on 19 Nov 2025 05:06 PM
Re: wifi slow
@dny1 If you want to ping then below is good for a 10 min test to the server, i aborted the test but enough to get you going!
ping bbc.co.uk -n 600
Pinging bbc.co.uk [2a04:4e42:400::81] with 32 bytes of data:
Ping statistics for 2a04:4e42:400::81:
Packets: Sent = 3, Received = 3, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 16ms, Average = 15ms
Message posted on 20 Nov 2025 10:33 AM
Re: wifi slow
Unfortunately skychecker https://www.sky.com/servicechecker
gives me
