Discussion topic: wifi slow
This message was authored by: Derricks9
wifi slow
I called sky and have tested wifi on line its says there is a problem can you resolve
Re: wifi slow
@Derricks9  If you called Sky did you only get the bot or did you speak to someone about getting whatever the fault is sorted?
