Discussion topic: wifi plugs
This message was authored by: angielou84
wifi plugs
does anyone know how to connect wifi plugs? none of mine are connecting and i cant access my router page
Re: wifi plugs
You may find they connect more readily if you temporarily turn off the 5Ghz wavebands in your router settings. What difficulty are you having getting to the router settings page?
