Discussion topic: wifi no working ,Unstable WiFi Connection in the Flat!
This message was authored by: Liz10
The Openreach team has installed the hub in a room close to the entrance, opposite the living area, where I used to keep the door closed to have privacy. This room is not too far from the rest of the flat. There is a corridor, another room, and the living room between the hub and the main living area.
As a result, the WiFi connection only works reliably in the room where the hub is located. To get any kind of connection in the living room, I have to keep all the doors open, and even then, the connection is unstable. This issue is particularly frustrating given that the flat is small; it is only a two-bedroom flat, yet the WiFi signal is weak.
Could you please advise on what can be done to improve the WiFi coverage in my flat?
This message was authored by: deepka
Re: wifi no working ,Unstable WiFi Connection in the Flat!
I had the switch to Optic fibre as on 06-July. Though, speed test shows over 130 MBps speed not experiencing real change with my browsing experience. Feel many of times, my mobile internet is better. Also, 2 times the internet totally stopped working and that too middle of important meetings
Avatar for Liz10
Re: Full fibre 100 wifi no working ,Unstable WiFi Connection in the Flat!
