27 Feb 2024 10:50 AM
Hi
I just installed Sky broadband. I can connect my mobile phones to wifi but I couldn't connect my laptop and desktop. I tried everything but couldn't show network in the wifi.
Regards
27 Feb 2024 11:25 AM
Posted by a Superuser, not a Sky employee. Find out moreWhich Sky hub do you have?
What laptop/desktop do you have?
How far away from the hub are they located?
27 Feb 2024 11:28 AM
Sky Max Hub
Surface 3
Just next room
Regards
27 Feb 2024 11:29 AM
Desktop-Lenovo
27 Feb 2024 12:08 PM
Posted by a Superuser, not a Sky employee. Find out moreThe Sky Max hub is WiFi 6 & uses WPA-3 encryption. Some older devices struggle to connect sometimes although I do not see why a Surface 3 would struggle. Do they not work even when right next to the router?
27 Feb 2024 01:33 PM
No it doesn't work next to the router. Upgrade the driver. It still doesn't work.
I am thinking to cancel my suscription. It took a lots of time to fix this instead of working.
Regads
27 Feb 2024 01:39 PM
Posted by a Superuser, not a Sky employee. Find out moreIf Sky can't help any further I'd recommend downgrading from Sky Max. There isnt much point in you having it anyway if your devices dont support WiFi 6.
