Discussion topic: wifi connection
This message was authored by bost This message was authored by: bost
wifi connection
i have my router in one room and sky q in another , it has connected before but seems to drop in and out of connection. my other appliance upstairs wont connect either to the broadband box
Re: wifi connection
@bostCan you tell us where the router is kept. is it low down or hidden from view or is out in the open and high up with nothing being it its way. Also as part of your pacake do you have broadband boost?
bost
Re: wifi connection
my router is currently on a small table with nothing surrounding it.
yes i took out boost last week but nothing has happened , not sure what boost package is
thank you
Re: wifi connection
@bostGive Sky a call and request a booster. They may ask you questions about the issues you are having before they send it out.
Just dial 150 on your landline and follow the voice prompts, but stay on the line and you should be put into the queue to speak to an advisor.
bost
Re: wifi connection
thank you
do you have a different number as i dont have a landline phone
Re: wifi connection
@bostYou can click on the link below and go to the bottom you will find " Need more Help ", click on broadband and it should give you a number.
https://www.sky.com/help/home
