Discussion topic: was missled and had my compansation refused as they lie
Message posted on 27 Oct 2024 09:26 PM
what should be the best course of action as i do not lie and dont like liers and i was promised
Message posted on 27 Oct 2024 09:28 PM
Re: was missled and had my compansation refused as they lie
@markaries30 Without much more info there isn't very much to go on, perhaps the full story would help?
Message posted on 27 Oct 2024 09:29 PM
@markaries30 You need to start from the beginning with the full story as to why you believe you are due compensation if you want us to help you
Message posted on 28 Oct 2024 08:11 AM
@markaries30 Sky operate the compensation scheme recommended by Ofcom which is explained here Customer Auto-Compensation | Sky Help | Sky.com
If you believe Sky are either not following thst scheme or a member of staff promised something else raiseca formal complaint How to make a Sky complaint | Sky Help | Sky.com. Sky record all phone calls so can listen to what was said. If you dont like the answer to your complaint Sky give you you can then take the complaint to an indepedent decision maker approved by Ofcom.
