Discussion topic: unable to connect my new HP printer to WIFI
This message was authored by: 19crr
bought a new printer which won't connect to WIFI but other devices phones, ipad have. had theis problem since we had a new router in december
Re: unable to connect my new HP printer to WIFI
@19crr couple of suggestions try using wps as explained here https://support.hp.com/us-en/document/ish_4641127-4645964-16 every Sky hub has a wps button usually on the tight hand side.
If you haveca white hub changecthe hub's WiFi security setting in the My Sky app to WPA2.
