Discussion topic: tv connection bad
This message was authored by: kendal1
tv connection bad
We recently had our wifi fitted and it is good in some rooms but when we try to stream movies and such on the telly it NEVER works, it's always cutting out saying "no connection" why is the wifi so bad when it comes to the telly
Re: tv connection bad
@kendal1Is your TV close to the Sky hub!
Avatar for kendal1
The hub is in my room and the tv is in living room. The living room is across the hall and we live in a small flat.
@kendal1 What hub do you have see the link, does not matter as not in the same room you just may not have a strong enough wireless wi-fi signal from the hub! TV's have some off the worst wireless connection systems out there!
