Discussion topic: Poor wifi
This message was authored by: Rich76495
Poor wifi
For a very long time, over 12 months I would say, o have always had poor WiFi.
three or four times a week I have had to turn it off, wait a short while, switch it back on and then restart by pressing the WPS button to help it find a connection .
I am at the point of saying enough is enough, if it cannot get resolved I will have to go a different provider. please can you offer a resulution
 thanks
Re: Poor wifi
@Rich76495 What is it that you are constantly having to reconnect to the hub, and which hub do you have from sky!
