Discussion topic: skyq booster
This message was authored by: leitchyleck
skyq booster
hi, trying to get signal down in mancave, its around 15m from house
currently have 4 miniboxes all working fine.  when i take nearest down to shed its hit or miss sometimes taking washing in helps!
i have a small white booster but think its from skyhd days, it pairs with rooter and shows connected but no improvement. do i need an up to date booster for skyq?
Re: skyq booster
@leitchyleck
There is a specific Sky Q booster (although not exactly 'up to date' as it's from 2016)
Sky typically won't supply one to get signal to an external building though.
Re: skyq booster
Re: skyq booster
@leitchyleck
Ideally you want ethernet running from your house to the exterior building, then you can have a reliable connection there from the mini box.
I am NOT a Sky Employee
Avatar for leitchyleck
Re: skyq booster
working for last hour. i restarted router/skybox & minibox, took in washing!
the booster is outside window but dk if its benifitting or not, will switch off when finished for night see if any changes.
