2
This discussion topic has been answered Discussion topic: sky router change
This message was authored by: edward3908
sky router change
Just finished a sky contract and agreed a new one. They have now sent me a new router and the new contract has better fibre speed.My question is simply can i re-use my old password and router  code so the i do not lose my smart home connections.tried thei tech man and he is stll checking..
Re: sky router change
@edward3908
In theory you can log into the new Hub using its administrator credentials and then change the broadcast SSID (network name) and WiFi Key (password) to match that of the previous model.
On the new white Max Hub this is done through the My Sky app.
@edward3908
Avatar for edward3908
Thank you very much for your prompt reply,i will try your suggestion.
Regards Edward
