Discussion topic: sky max pod registration
This message was authored by: HelenN60
If you buy a second hand Sky Max Pod from ebay, you are basically buying a very expensive paperweight. If you try and register your second hand pod to your your MySki  Max subscription it will not do so as it has already been registered to the previous owners subscription/account and will not accept the registration number that's on the back of the pod. So be aware if do manage to get hold of a used Pod on Ebay it will not work. The contract states that they are only loaned to you and you must return them when your contract has finished.
